Billman's Brake Fluid Gravity bleeding revised
Old Jan 22, 2021 | 04:08 AM
  #121
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you are starting from scratch with a largely airbound system, bleed order matters.
In the case of a fluid replacement (no air introduced) the order does not matter.
Old Jan 22, 2021 | 08:38 AM
  #122
cosmomiller's Avatar
Top Answer: 1
Question: Does the fluid replacement, lets say no air present, replace fluid in the ABS and VSA components?
Old Jan 22, 2021 | 02:01 PM
  #123
mgedit's Avatar
Interesting thread, and something I would like to do this Spring. Seems that blue fluid is no longer legal/produced. Is this correct?
The blue colour was an obvious advantage for knowing when all old fluid was flushed. Is it as obvious with regular gold colour fluid if existing stuff still looks good? Any hints would be much appreciated, assuming there are no longer coloured options..
Cheers, Mike
Old Jan 22, 2021 | 02:51 PM
  #124
EffWun's Avatar
Thanks, I am unsure of some of the cars I'll be doing soon so will do conventional order.
No more color for a while. Maybe can do a very small amount of colored hydraulic fluid into the brake fluid to add color?
Old Jan 22, 2021 | 03:51 PM
  #125
Hfreak's Avatar
Just use clean and clear fluid, when it starts to yellow then you know you need to flush it again.
exileut
Jul 27, 2014 03:54 PM
Opie Oils
UK & Ireland Traders Forum
Dec 15, 2010 03:56 AM
owenxguo
Apr 7, 2005 09:02 PM
