Billman's Brake Fluid Gravity bleeding revised
Old Dec 17, 2012 | 08:46 PM
  #31
leemaverickly's Avatar
Thanks Billman.
I have a question about step 1 and 2. If we empty the master cylinder thoroughly, wouldn't air get into master cylinder?
Old Dec 20, 2012 | 07:08 AM
  #32
faxter18's Avatar
Originally Posted by s2000Junky
Originally Posted by faxter18' timestamp='1355689106' post='22213822
I'm looking to change my brake lines to SS. Should I do a flush first and then install my SS lines and add more break fluids? My master cylinder looks pretty nasty. I figure this way would be using more brake fluid, but will keep my lines clean.
It makes sens to me to drain the entire system to remove the brake lines, then once everything is installed, perform the gravity procedure. In this case your waiting for fluid to come out of each caliper, rather then just turning blue from the old to new fluid.
Thanks for the advise. I was thinking I should go that route as I was looking to paint my calipers. I figure I should take all the down time at once.
Old Dec 20, 2012 | 07:37 AM
  #33
acn684's Avatar
Not to overshadow the expert here, but add disclaimer to wipe off any brake fluid if it spills on your paint immediately. That stuff will eat away at clearcoat and paint.
Old Dec 20, 2012 | 08:33 AM
  #34
dwight's Avatar
I'm under the impression that you should just rinse it off with water. Wiping can smear softened paint.
Old Dec 20, 2012 | 10:45 AM
  #35
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Yes best thing to do with spilled brake fluid is hit it with lots of low pressure water.
Old Dec 20, 2012 | 10:46 AM
  #36
Billman250's Avatar
Top Answer: 1
Originally Posted by leemaverickly
Thanks Billman.
If you follow the steps in order, you will get no air at all in the system.
Old Dec 20, 2012 | 05:56 PM
  #37
deepbluejh's Avatar
Is there a certain size hose you guys would recommend using for this?
Old Dec 20, 2012 | 08:26 PM
  #38
Yoohoo's Avatar
I just use flexible airline aquarium tubing. You can get 25ft of it for like 3 dollars. I think the size of the tube is 3/16" but don't quote me on that.
Old Dec 30, 2012 | 02:38 PM
  #39
Does it matter whether i leave the handbrake up or down while bleeding the brake fluid?
Originally Posted by Billman250
Originally Posted by leemaverickly' timestamp='1355809563' post='22216751
Thanks Billman.
Old Dec 30, 2012 | 05:10 PM
  #40
dwight's Avatar
The handbrake is cable driven and independent of the hydraulic braking system. (No, it doesn't matter. Either way is fine.)
