Billman's Brake Fluid Gravity bleeding revised
Old Jan 4, 2013 | 01:04 PM
  #51
dwight's Avatar
Correct, the handbrake isn't one of those hybrid disc/drum systems where the handbrake actuates the shoes.
Old Apr 14, 2013 | 06:59 AM
  #52
crisskro's Avatar
I had to remove the rear brake cylinder for maintenance, now it seems I have air in the system. Can I gravity bleed only the rear one to get the air out?
Old Apr 26, 2013 | 10:16 AM
  #53
01_S2k's Avatar
I just did this the other day and man it made such a difference, pedal is way tighter and more responsive. Good DIY for sure.
Old Apr 26, 2013 | 10:27 AM
  #54
BlakeNFR's Avatar
The only way to insure it doesn't travel through the lines is to completely rebleed the system.
Old Sep 12, 2013 | 12:46 PM
  #55
nadeem's Avatar
Billman, you state to let it drip until it turns deep blue. This is easy to notice if you are flushing OEM fluid since Super blue is Blue.
How about if you are flushing existing superblue fluid that is fairly fresh. I say this because my pedal is inconsistent and i want to correct it with your method.
Thsnks.
Old Sep 14, 2013 | 02:35 AM
  #56
INDYMAC's Avatar
You have to buy the amber to alternate with the blue.
Old Oct 27, 2013 | 07:47 AM
  #57
av8ter's Avatar
Just swapped out all my original fluids yesterday. I ended up with a spongy brake pedal(not floaty, spongy). I started with a gravity bleed on all 4 corners after exchanging the fluid in the reservoir followed by pressurized bleed at each corner by pedal once all the fluid was exchanged. Only problem was I accidentally ran the reservoir dry by accident while I went to balance the tires.
I proceded to bleed by pedal force at all four corners untill i *thought* I got all the air out. I went RR to LR to RF to LF not knowing the proper bleed sequence and now I am left with a pedal less firm than before. I am in process of trying the "brick method" currently and will report back with my findings but I have a feeling I will need to re-bleed the system.
Old Oct 27, 2013 | 07:55 AM
  #58
gptoyz's Avatar
you may need to purge the master cylinder of air, which i do not know if the gravity bleed method will resolve your problem.
you may need "bench bleed" your master cylinder to prime it first before switching to gravity, 2 man, brick or whatever alternative method you choose.
also the following are the bleed orders:
billman's rf, lf, lr, rr
oem honda lf, rf, lr, rr (closest to furthest point from the master)
i'm not sure where the whole start from the furthest point procedure started.
Old Oct 27, 2013 | 11:27 AM
  #59
av8ter's Avatar
3-4 hours of the brick method yielded no positive results. There must be air in the MC and or ABS pump. Ughhhh. Oh well.
What is the best(for our s2000s) "bench" bleeding kit to purchase?
Old Oct 27, 2013 | 11:47 PM
  #60
gptoyz's Avatar
I used this dorman kit from o'reilly auto parts
http://www.oreillyauto.com/site/c/de...0678&ppt=C0067
