Bizarre Coil Pack Problem - help!
Old Jul 7, 2022 | 08:16 PM
Iyan112's Avatar
Originally Posted by RolanTHUNDER
Thanks for this! I'm thinking it could be a bad fuse so I'll swap it out with another good one including the under hood number 46 fuse just in case. I'll try to get my hand around to the G101 wire and see if it's loose in any way.
Will also connect my laptop and see what the AEM Tuner shows up
I don’t think it be a fuse. Same fuse powers all so if it was a fuse, none would fire. I’m leaning towards a signal issue that’s not getting sent from the pcm or a open wire in cyl # 4 harness
Old Jul 7, 2022 | 08:24 PM
windhund116's Avatar
Originally Posted by Iyan112
Daym that looks like a huge gap. Definitely looks like the gap is too large to make a good spark. Out the box my plugs came .030 of the same plugs. I was experiencing spark blow out at that gap and dropped them down to .021 and my problem went away.
I wonder what caused the gap to widen to that gap? Weird?
Old Jul 8, 2022 | 04:14 AM
RolanTHUNDER's Avatar
That's the thing. You are probably right. I'm hoping for a fuse as that's the easiest to replace. If there's an open wire how am I going to find it without cutting open the insulation...?
Old Jul 8, 2022 | 04:17 AM
You and me both. I think that set of plugs was fake. No other reason I can think of. Now the question is, could that specific plug which has the widest gap (although all of them are just about that wide in terms of gap) have caused a wiring issue in coil pack connector 4??
The AEM EMS is obviously working well to the point that it does fire the AP1 coil in cylinder 4 and before this it fired any other new coil until the coil stopped firing while I drove...
Old Jul 8, 2022 | 04:55 AM
Iyan112's Avatar
without opening up insulation, ohm out Or continuity test of individual wire. Measure one end of wire and where the other end is with a Multimeter and see if you get a reading. With the meter if you have a audible one and you test the individual wire itself, it would make a beep sound or display reading In ohms. If there’s a break in that wire, it will display OL
Old Jul 8, 2022 | 05:00 AM
Iyan112's Avatar
i know with heat and cooling can cause the metals to expand over time but not that large unless it’s a crap plug. Only other thing is possibly it was overlooked and forgot to get gap prior to install?
Old Jul 9, 2022 | 06:08 AM
That's an excessive gap though. I got rid of those plugs and put my genuine NGK set back in so that's ok.
No need to gap them. Even this fake set looked like a much smaller/tighter gap prior to install.
Old Jul 9, 2022 | 06:13 AM
So I did more testing today and might be scared at what I found. Ground wires all seem to be good. I decided to look at the ECU end of the wiring harness so I removed the AEM Series 2 and tried the ohm/continuity test again. There was no continuity at coil pack connector 4 or 3. The only thing present was continuity for the battery voltage (middle and rightmost terminals of the coil connectors). I then decided to connect my stock ECU and do the same test. The very same results as above! No continuity between the ECU control terminal and the middle terminal of the coil pack connectors!! I even switched the ignition on just to see if that made a difference to the test but nope... The same results. 0 continuity (no beep or red light) on the multimeter when I probed the coil pack connectors on their ECU and middle wire terminals.
So what do you think? Physical AEM EMS issue?
Old Jul 9, 2022 | 06:16 AM
And i could not find any clear wire breaks or shorts but I did not open up the harness. After this multimeter test I doubt that's needed anyway and we can (probably) safely assume that there is no physical wiring problem. I even swapped ignition fuses just in case before doing the test so the fuses are good
Old Jul 12, 2022 | 09:56 AM
AEM replied:
"The previous spark plugs could not put the EMS into some sort of failsafe mode. There isn’t one. Bad plugs could damage Coils but not coil drivers within the EMS. Your resistance readings sound within spec old or new. The difference is nil.
No burned wires and all OEM does not really mean much when you are talking about a 20 year old car.
If you can rev out on any type of coil used, it means that the issue is mechanical maybe wiring related in that the plugs on either the coil or the harness may be the culprit".
Note: the good news is after changing out those crappy plugs I can now rev out to 9200 with no hiccups! That being said, cylinder 4 only plays nice with the AP1 coil pack I currently have in it. All other new ones suddenly don't fire when connected there.
Stoner_1
Jul 6, 2022 10:57 PM
DutchyFutch
Oct 22, 2015 06:41 PM
KC2001AP1
Feb 10, 2013 03:23 PM
Jagga_s2k
Sep 12, 2010 10:31 AM
Billman250
Mar 4, 2007 07:18 AM
