my ap1 build has no spark
Hey guys we'll this is wht hapend. It has no spark changed. Coils n plugs n checkd al grounds. Wht we did was built a new motor. Old one spun bearings. Its a jdm f20. Put ap2 crank n rods. Ap1 pist al new rings n bearings. Fresh head with supertech flat valves dual springs n ret. And ap2 intak cam n ap1 ext (gave it to a freind cus I'm planing on geting biger cams). Botom end was asembled by the machine shop n rest by us. That's prety much. It. The orignal motor ran fine. Just spun bearings. That prety much the story just short.
Wht could cause it not to hav spark and not run. Any ideas anything I could have missed. Help me out here I'd realy apricate it.
What valve cover did you use? IIRC the 04+ (or 06+?) has different cam angle sensors (only one) that will not work with the AP1 ECU.
Otherwise... it would have to be a wiring issue unless you didn't put the cam angle sensor plates on the cams.
