Blow by
Old Mar 10, 2022 | 05:07 AM
Dose13's Avatar
Default Blow by
So ive recently turbo and tuned my 06 Ap2 , never really got around to getting a catch can installed only been a few weeks since tune , never saw the car its self over heat by the gauge inside however started to sounds like a miss fire and tons of blow by and after a good pull dip stick even shot up. i did notice my spal fan was not on . no milky oil cap . what yall think blown head gasket or bigger issue???
HELP .
TY
Old Mar 10, 2022 | 05:27 AM
B serious's Avatar
What were the compression test/leakdown numbers?
Old Mar 23, 2022 | 07:01 AM
Dose13's Avatar
cyl 1 -180
2-150
3-150
4-60
Old Mar 23, 2022 | 08:27 AM
s2000Junky's Avatar
Cylinders toasted. Or bent or cooked valves. Can do a leakdown to confirm which. But if blow by/dip stick blowing out, then likely cylinder issue.
Old Mar 23, 2022 | 03:43 PM
windhund116's Avatar
I guess it could be a blown head gasket? You could do a coolant pressure test?
Old Mar 23, 2022 | 04:18 PM
noodels's Avatar
quote: started to sounds like a miss fire and tons of blow by and after a good pull dip stick even shot up
So it may have been a coil / ignition problem ..
Now may have cylinder damage,
been there done that >> = another engine
for you.
Akkmednoseflem
Oct 2, 2018 04:21 AM
Akkmednoseflem
Sep 21, 2018 11:51 PM
TixonPB
Jan 15, 2015 02:01 AM
nextinstant39
Feb 23, 2009 04:02 PM
ChefJ
Aug 2, 2007 06:18 AM
