Blow by
So ive recently turbo and tuned my 06 Ap2 , never really got around to getting a catch can installed only been a few weeks since tune , never saw the car its self over heat by the gauge inside however started to sounds like a miss fire and tons of blow by and after a good pull dip stick even shot up. i did notice my spal fan was not on . no milky oil cap . what yall think blown head gasket or bigger issue???
HELP .
TY
HELP .
TY
Cylinders toasted. Or bent or cooked valves. Can do a leakdown to confirm which. But if blow by/dip stick blowing out, then likely cylinder issue.
quote: started to sounds like a miss fire and tons of blow by and after a good pull dip stick even shot up
So it may have been a coil / ignition problem ..
Now may have cylinder damage,
been there done that >> = another engine
for you.
for you.
You could do a coolant pressure test?
