bottomed out bad...
Old May 5, 2007 | 07:07 PM
s2jay's Avatar
Banned
Default bottomed out bad...
...i came across a few tall speed bumps last night (no way around them) and scraped the sh*t outta the bottom of the car at least 3 or 4 times. as you all know the invidia tp places the o2 sensor lower than most of the undercarriage. i believe this is what i was hitting so as i look this morning i notice the bottom is filed down flat. anyways no CEL but today on a cold start, i had major backfiring/popping between gears when i pulled out. im wondering if this had something to do with it. other than that...how bad can it be to smash the sensor a few times here and there? whats the worst that can happen? ps...the backfiring sounded sick, kinda liked it
Old May 5, 2007 | 07:25 PM
S-Turn AP1's Avatar
If you hit the o2 sensor going over the speed bump replace it ASAP, its most likely causing the backfire/pop.
I have the same test pipe and with the sims on it sticks about a half an inch lower than anything forward of the rear suspension. It really scares me when i have to go over speed bumps
Old May 5, 2007 | 08:35 PM
Stratocaster's Avatar
Did you think about raising the car but up?
Old May 5, 2007 | 09:25 PM
s2jay's Avatar
Banned
negative...these were monster speed bumps. almost like curbs
Old May 5, 2007 | 09:30 PM
R3DS2K's Avatar
any cel?
Old May 7, 2007 | 02:10 PM
s2jay's Avatar
Banned
no cel. but now the car is running a little funny and a friend claims to see blue-ish smoke from the exhuast! could this all be caused from the o2 sensor or is this a whole other problem? if it is this sensor...anyone know how much these go for?? someone out there HAD to have gone through this...????? HELP
Old May 7, 2007 | 02:17 PM
s2kBryan916's Avatar
I would say replace it. The are about 200 bucks for an OEM.
Old May 7, 2007 | 05:20 PM
s2jay's Avatar
Banned
besides a cel, what would happen if i removed the o2 and capped the hole in the tp? any thoughts on the blue smoke?
Old May 7, 2007 | 05:33 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The pop/backfire is re-burn from an exhaust leak. You may not hear it, but you definitely have a crack or leak somewhere in the exhaust.
Old May 7, 2007 | 05:37 PM
R3DS2K's Avatar
blue smoke usually mean your burning
running with no o2 will mean your cars going into limp mode.. no vtec.. and car runs on default settings
