Brake Question
Old Oct 11, 2009 | 01:25 PM
E-Z's Avatar
E-Z
Default Brake Question
I have an HPDE coming up in a few weeks, so I decided to check my brakes today to make sure everything was OK. Turns out I need pads, but I found this on the right front.
Fluid came out when I tipped it up, but I'm assuming that fluid was water and not brake fluid. It wasn't blue, so I'm pretty sure it wasn't fluid as I run the ATE Super Blue.
Is this a problem? I've been searching the forum and still can't figure out exactly what it is. Is it the piston seal? A dust cover for the seal? Is it important?
Old Oct 11, 2009 | 01:44 PM
cdelena's Avatar
Those dust boots get fried and worn on many cars (actually yours are better than mine) but without any negative impact. I would ignore the wear for now.
Old Oct 13, 2009 | 07:00 PM
E-Z's Avatar
E-Z
Thanks for the reply. So what's the purpose then?
I track this car. Is it still not an issue?
Old Oct 14, 2009 | 06:53 AM
luder_5555's Avatar
with a torn boot, you will likely develope a sitcking caliper over time. ar long as you are not loosing any fluid you should be safe, although if a caliper starts to stick you will go through pads quickly and unevenly.
i would suggest a rebuild. or if you like to track, this is the perfect excuse to upgrade to sone more potent brakes
Old Oct 14, 2009 | 08:24 AM
B serious's Avatar
Upgrayedd to more potent brakes because of a torn boot that comes in a $20 rebuild kit? That's a really bad excuse to spend $1500-3000.
My boot got burned too. It's just a dust boot.
Old Oct 14, 2009 | 02:31 PM
E-Z's Avatar
E-Z
OK thanks! I'll keep an eye on it. I was just worried that it was something that needed to be taken care of ASAP.
berlinabob
May 20, 2014 01:25 PM
S2kRally
Apr 2, 2010 07:02 PM
Moddiction
18
Apr 4, 2009 11:14 AM
anthonys2k
Sep 3, 2006 10:26 AM
havoc UK
Jul 10, 2006 03:26 AM
