Broke off a bolt in the head
So after installing my clutch and reinstalling my supercharger, I realized that my VTEC solenoid had a small oil leak. I decided to tighten up the three bolts a little to see if it would solve the problem. The bottom right one snapped off (cheap NAPA bolts!!!) and the end of it is now stuck in my head... I've never done an extraction before, how would I go about getting it out?
Thanks,
Sam
Thanks,
Sam
First, remove the other 2 two bolts and take the solenoid off. If you're lucky, the broken bolt will be sticking up and you can grab it with ViseGrips. Bolts often break just under the head of the bolt and removing the part exposes a section of the bolt the thicknesss of the flange they were holding to the head.
Check this out first: you need that solenoid off anyway if you have to remove it one of the harder ways.
http://buy1.snapon.com/catalog/tools.asp?t...re=snapon-store
you might be able to do it by hand or angle driver
