Broken Clutch?
Old Aug 6, 2012 | 11:08 PM
DavidDao77's Avatar
Default Broken Clutch?
Hi guys, I've owned a white S2000 for a while now, but I am very noobie to this forum. I apologize in advance if I post in the wrong category.
I don't know much about cars so I'm seeking for S2000 pro advice. Thanks
So right now my S2k is sitting in my parking lot unable to drive. Here are the reasons:
1. I can't shift my gears. Whenever I try to shift the gears are stuck. I can't shift it into any gear 1-6 or even reverse.
2. My clutch feels very weird. I feels like spring broke or is loose. Whenever I push my clutch all the way in, it does not have the tension that it use to. The clutch no longer eases back after I let it go, it snaps back.
3. The first 2 issues above occur only when I turn on my car engine. However, if the car is off, I can shift gear any way I like with or without clutching in.
4. Finally, the car is able to shift when I start it in first gear, and as of now it seems to be ok when starting in first gear.
5. Before all of this started happen, my clutch would literally choke in a middle of a drive. I would come to a stop and the gear box would not shift.. If feels hard as a rock whenever I want to shift it.
Please help me out if you can guys. I'm already p
Old Aug 7, 2012 | 12:26 AM
realblag's Avatar
Most likely your clutch slave cylinder or master cylinder is shot. If you have fluid in the floor of the car, the master is dead. If there is fluid under the car, the slave is dead. You may not have any fluid left in the reservoir.
Old Aug 7, 2012 | 10:29 AM
Jspd's Avatar
Check the slave cylinder and the fork it presses on to release the throw out bearing. My fork somehow came off the pivot point and was pivoting off the trans case. My car locked up and I was unable to change gears. I would guess that or one of the springs came out of the cage on your clutch. Hope that helps!
mongomery1234
Apr 5, 2017 07:29 AM
DavidDao77
Aug 7, 2012 07:17 AM
planeman01
Nov 30, 2011 02:50 PM
Road Rage
Mar 26, 2004 05:28 PM
stooklova
Jun 29, 2001 09:21 PM
