Broken motor/tranny mounts. how to diagnose?
Old Jun 21, 2008 | 01:27 PM
news2kroller's Avatar
Default Broken motor/tranny mounts. how to diagnose?
Hello, I think i may have a broken motor/tranny mount. I have vibrations at low rpms and think it may be a broken mount. Can somone tell me what i am looking for in both cases to diagnose the broken mount. thank you. CHRIS,.
Old Jun 22, 2008 | 11:51 AM
Bump for some help???
Old Jun 22, 2008 | 12:01 PM
Stratocaster's Avatar
They are both solid rubber. I engine mounts normaly break just under the top metal part. You should be able to just the motor just a bit to see if they seperate there.
Old Jun 22, 2008 | 05:29 PM
fuel4blood's Avatar
let your car idle with the ac of then turn the ac on if the vibration gets worse its probably a motor mount. Finding which mount it is is a bit tricky especially if the crack in the rubber isn't visible.
Old Jun 22, 2008 | 05:37 PM
Ray's Avatar
Ray
You might be able to see the brown fluid mark coming down the side of the mounts. It's rust colored.
If you see one of the engine mount broken, chances are the other one is broken too.
stakss2k
Apr 20, 2014 05:28 PM
buzz944
Apr 7, 2010 03:47 AM
SpoolinU
Feb 1, 2010 12:55 PM
Ripcurl808
Sep 6, 2009 10:35 AM
mikegarrison
Jul 26, 2004 11:41 AM
