motor mount slightly off the holes
Old Apr 20, 2014 | 11:00 AM
stakss2k's Avatar
Default motor mount slightly off the holes
Installing the new clutch and my mechanic took off the screws at the bottom of the cradle because he figured the tranny wpuld lean better well when he did so my motor mount on passenger side came off and now resting on the cradle I tried picking up the whole motor from the oil pan with a jack and all it does is put more pressure by bring it up , my motor mount just needs to be moved a little so it can insert inside the holes where they belong but I cant figure out how to do it amy help please ?
Old Apr 20, 2014 | 05:26 PM
MM3Kwolik's Avatar
Loosen the top nut a bit and jack up the engine slightly. Then align the mount, and lower it back down into place. Tighten the 3 nuts and you're done.
Old Apr 20, 2014 | 05:28 PM
Fokker's Avatar
Are you jacking it up on the side closest to the mount you want to align? I just finished swapping out the driver side and jacking it up close to the driver side allowed me to easily align it.
Competitor9
May 10, 2012 10:40 AM
news2kroller
Jun 22, 2008 05:37 PM
ChefJ
Oct 3, 2007 08:46 AM
mikegarrison
Jul 26, 2004 11:41 AM
