innovative mounts
Originally Posted by Neutered Sputniks,Jan 31 2010, 04:54 PM
I don't see why you wouldn't. It's the easiest mount to replace...
Originally Posted by SpoolinU,Jan 31 2010, 08:10 PM
it might be easy but i found them for like 450-750 bucks for mounts.. thats alittle crazyy
Thought you were talking about tranny mount, not diff mounts. NVM>
Originally Posted by SpoolinU,Jan 31 2010, 01:09 PM
is it necessary to replace the differential mounts?
BTW... how do u like the motor mounts? I'm about to buy some myself... which bushings did you go with?
Originally Posted by 21337R,Feb 1 2010, 02:37 AM
Are they broken? If not then I would say.... NO
Bit of a bitch to get on by yourself, but doable. I haven't had a chance to drive the car since installing them, so I can't give you a solid review however I can assure you the mounts are more solid than the stockers
BTW, I've seen that the 60A (red) bushings deform. There's a thread somewhere in these very forums that discuss it (apparently it's an issue Innovative knows about). I'd recommend going with the stiffer bushing (75A) to be on the safe side, YMMV.
i went with the 75a(black) but haven't had the chance the drive the car yet either i just installed them, and want to make sure that i don't need to replace the differential mounts with stiffer ones.
bgoetz
Aug 23, 2014 03:21 PM
news2kroller
Jun 22, 2008 05:37 PM
