building up engine
Old Jan 30, 2003 | 10:07 AM
wega_85's Avatar
Default building up engine
if i purchused spoon valves and retiners would it be better to intall it after i break-in the engine or could i put it in right after and break it in togther? does anyone have spoon valves and retainers?? does it really help your engine at high RPM??
Old Jan 30, 2003 | 10:49 AM
Gernby's Avatar
Former Sponsor
Unless you are going to raise your rev limit, the stock valves should perform just as well as the spoon valves. Are the Spoon valves polished better than the stock valves?
Old Jan 31, 2003 | 01:06 PM
AJ PwR's Avatar
The Spoon vlaves are polished and much lighter than stock. Stiffer valev springs not just benefit hi rpm revs , it also improves mid-range power 2-4whp.
Old Feb 1, 2003 | 01:51 PM
VTECPHIL#6829's Avatar
I would do the Hondata Insulator gasket and save the money and same/better gains. About $55.
Old Feb 1, 2003 | 02:59 PM
wega_85's Avatar
but if i do install the valves and retainers will i need to break in the engine again?
Old Feb 2, 2003 | 02:14 AM
Sunder's Avatar
Probably, you'd want them to seat properly, and the "beneficial" layer of carbon to form.
But... Like they said, if you aren't going to raise the rev limit, why bother? Gains will be minute for the price (You know that the headgasket kit is about $150 OEM?)
The reason that you want lighter valves and stiffer springs is to prevent valve float and hence piston to valve contact.
Old Feb 2, 2003 | 09:10 AM
455guy's Avatar
There is no break in time on valves and springs. once they are installed properly(meaning three angle valve job) they are set. You can't just throw in valves, you must cut the valve seats so that the valve seals correctly when closed. There is no such thing has "beneficial" layer of carbon. Carbon will soak up fuel, the more carbon bulid up, the fuel will be soaked up(not good). Unless you planning on changing cams or sc the engine, valves and springs are the last thing to due.
Old Feb 6, 2003 | 08:50 AM
OneQuickS2K's Avatar
Lundunb
Apr 26, 2006 01:51 PM
S2k BF
Jan 18, 2006 11:23 AM
WVT
Nov 30, 2005 08:37 AM
chamich
Aug 26, 2003 08:43 PM
tze
Oct 19, 2001 05:29 AM
