Bumpsteer racking my brain
It's almost as compliant as Oem I guarantee you can't tell the difference, also poly bushings aren't great for our cars, it's your car obviously, but I personally wouldn't waste my money on poly bushings. Rubber lasts and is much more maintenance free.
Should I get the pillowball hardrace or just the hardrace rubber?
Rubber is much cheaper, I'd go with that, pillow ball on a street car is very annoying, it'll add a lot vibration to the suspension. Granted you could probably get away with pillowball compliance bushings rubber everything else, but cost is a factor. Those pillowball bushings are very expensive, plus they're not as maintenance free as the rubber ones.
Wait...why is tightness of bolts relative to wear of bushings? I don't believe needing to tighten bolts further than normal has anything to do with bushing wear.
Rubber bushings have a metal sleeve that the bolts clamp. The metal sleeve never wears out.
Worn bushings can cause alignment issues and bumpsteer. Have the bushings always been clocked properly?
It also may be because you have extended upper AND lower ball joints. Its the same as making your spindles longer on both ends. Your UCA/LCA angles and curves will differ a lot from stock.
I really hope the bushings are the main culprit not just an addition to the issue. The next thing I can think of is the rack itself, which has already been replaced and been working fine for years.
I was having this issue before I installed the lower ball joint. Before last May the upper ball joints gave me no issues, I even took the car to the track and multiple autox sessions for the past 4 years and no issues until last May.
Update* So I replaced the front LCA and UCA with Hard race harden rubber bushings. The car feels better and doing the alignment is a breeze BUT the bump steer is still there. Next I'll be replacing the steering rack and hoping that will be the end all be all.
I have EVS rear toe arms. With the multiple alignments I've done the arms don't change toe with the specs I want.
