Burning oil
Hey i got my used 2002 S2k about 2 months ago and it had 6500 miles on it and not it has 7700 about 500-700 miles ago i put in about 1/2 a qt of oil in it and today my friend who was behing me said he saw a little white smoke comming out when i accelerated so i check my oil and it is about 1/2-3/4 down. Could i be burning oil what could be wrong do i take it in. Not sure But im getting kinda worried now
My car has a tendency to USE oil. As long as the smoke is not BLUE in color you should be fine. If I have not got on it for a bit, my car will show white smoke out the exhaust when I do, but this is normal as our cars tend to run rich and this builds up and needs to be blown out every now and then.
However, as I stated above, my car does USE oil and always has. I normally use about a quart between oil changes. But again, this is normal for me.
if the smoke is a cloudy-milky color, it could be a head gasket problem...coolant is entering the combustion chamber.
if the smoke is light/dark gray, its just that the car is running rich (DOHC VTEC motors run rich during vtec ).
if the smoke is any shade of blue, you are burning oil due to bad oil rings or a number of other possibilities.
stupkid
Nov 7, 2011 03:12 PM
S2K
Jul 27, 2002 12:39 PM
