Buzzing noise coming from engine
Old Oct 1, 2016 | 09:43 AM
AbsoluteFreedom's Avatar
Default Buzzing noise coming from engine
Buzzing (maybe a fast tick???) noise coming from my AP2, even after changing out the TCT
Does not happen at idle but you hear it with any throttle application. Seems like its coming from the top front of the engine but I could be wrong.
Thoughts?
[media]https://www.youtube.com/watch?v=qb3eHXNuoHQ[/media]
Old Oct 1, 2016 | 09:52 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Possible TCT noise, is it an oem tct?
Old Oct 1, 2016 | 10:14 AM
Just got done replacing the TCT with a Ballade unit. Video was recorded afterwards.
Old Oct 1, 2016 | 11:04 AM
Billman250's Avatar
Top Answer: 1
Was this noise present before replacement?
Old Oct 1, 2016 | 11:30 AM
Yes it was, the TCT was done to attempt to alleviate this noise
Old Oct 1, 2016 | 12:38 PM
windhund116's Avatar
Worn pully(s)?
Old Oct 2, 2016 | 02:38 AM
Car Analogy's Avatar
It sounds like its idling very high. So that makes me think maybe the engine was cold when the video was shot. So that makes me ask, is the noise still there once it warms up? Is noise any different when warm?
To see if its the pulleys like someone suggested, just remove serp belt, and start engine. Obviously don't drive around like that or run engine too long, or it could overheat. You don't even have to fully remove belt from car. Just take slack off tensioner, and unloop from tensioner pully, and just let belt hang there. That will be less work wrestling belt out then back in and tracing path around pulleys.
While belt is off, spin the tensioner and idler pulleys by hand, make sure they spin smooth and quiet.
Old Oct 2, 2016 | 02:39 AM
Dup post creatwd by stupid forum app.
Old Oct 2, 2016 | 06:32 AM
Yes the car was cold. The noise persists when the car is warmed up. I will see what I can do to check the pulleys. Are there any reference videos for that noise?
