A/C charge
Old Jan 18, 2008 | 03:21 PM
P-CarDriver's Avatar
Default A/C charge
So i was wondering, will my a/c charge die faster if i dont use it or will it die faster if i use it alot?
Old Jan 18, 2008 | 04:17 PM
Slows2k's Avatar
The rate at which it can leak out is dependent on the size of the leak.
If the system is used daily vs being used once a month it doesn't matter.
I'd run it once a month to keep the oil throughout the system.
It's a sealed system designed to hold refrigerant in at high pressures.
Old Jan 18, 2008 | 06:41 PM
2poor2mod's Avatar
use should not matter, it is usually a result of age that things go bad in an ac system. the seals over time can get dry and cause a leak to occur and the ac charge to be lost. Like Slows2k said just use it once in a while in the winter months to get the oil distributed throughout the system so the seals dont rot.
Old Jan 21, 2008 | 03:42 PM
iam7head's Avatar
freon doesnt get used up, if you running low you are having a leak somewhere, maybe from a bent hardline, a leaky seal.
don't just recharge it and forget it, find out why you need to refil in the first place.
jjaypal
Apr 18, 2017 09:14 AM
paS2K
Apr 4, 2014 11:38 AM
PokS2k
May 23, 2010 12:43 PM
ScienceofSpeed
Feb 18, 2009 12:46 PM
