A/C is not cool enough?
standard temperature for A/C should be about 25 degrees below ambient temperature, no matter how hot ambient temperature is. from what i know, and talking to various mechanics, this is the industry standard. if it's 100 degrees out your A/C is not going to blow at 40 degrees. use recirculate and your car will cool down. no A/C system is perfect. it will leak over time. have your A/C serviced. more than likely the pressure is low and it just needs a recharge. if that doesn't work you probably have a bad line or compressor.
