C101 connector pinout?
Old Aug 5, 2010 | 10:56 AM
ae86F20c's Avatar
Default C101 connector pinout?
Hi, i need to know the pinouts for this connector. Just in the middle of getting my f20c swap wired in my ae86. I've searched everywhere for this an can't find it .
Any help greatly appreciated.
Old Aug 5, 2010 | 05:53 PM
GPW AP2's Avatar
Do you have any idea what that connects to? I see it in the manual and it is in the drivers footwell, but I cannot find a digram for it?
John
Old Aug 6, 2010 | 10:01 AM
ae86F20c's Avatar
It connects to the dash harness from the engine harness. I think their is only 6 wires in it i need to get it running, 1 is the starter wire, grounds an something else ?
I have the service manual but it doesn't give a diagram for it. If anyone had an electrical book it should give it. It's called c101 an is a light blue color.
Old Aug 8, 2010 | 12:05 PM
ae86F20c's Avatar
Just found it der said i'd post it up in case anyone else needs it.
1 - ignition system BLK/YEL +12v - connect to the ignition key
2- Air conditioning- not connected
3- starter motor -BLK/WHT- +12v through starter motor switch
4- YEL/BLK +12v from ignition switch- power supply to ECM
5 -BLK/YEL +12v lambda sensor - connect to ignition key
6- YEL/BLU air pump - not connected if you do not use air pump
7- WHT/BLU - alternator light(on the dashboard)
8- BLU/WHT - VSS sensor connected probably to the speedo gauge
9- YEL/RED - low pressure warning light(on the dashboard)
10- WHT/RED +12v ECM/ immobilizer light
11- YEL DRL indicator light- proably check engine light but not sure- in my car it is not connected
12- GRN/YEL - not connected
13 - WHT/BLK - secondary air injection system- not connected
14 - BLK- ground
15 -BRN/YEL - DATA LINK CONNECTOR - this is only one of few wires that go to data link connector- rest is probably in the ECU 32P socket.
16- GRN/YEL air pump - not connected
91crxSi
Sep 15, 2013 09:52 PM
geared
Aug 25, 2012 05:49 PM
Walezy
Aug 11, 2008 10:52 AM
01silverstones2k
Aug 22, 2007 06:25 PM
