c32 swap
hey guys, i was laying in bed thinking about my s2000 last night, and i thought about an NSX, then i thought about the NSX motor, then i thought about the NSX Motor in my car. can it be done? i understand it wont be bolt in, but how much fab/mod are we looking at?
Yes it is possible to swap a c32. The only problem is you'll have 6 gears for reverse and one gear for forward
The motor spins the wrong way, it would take considerable effort to make it work and BIG $$$$$$
No. It can't be done. There are a lot of reasons, but some big ones would be
1.) The transmission for the NSX motor is mounted sideways in the chassis, whereas the S2000's is mounted in-line with the transmission tunnel.
2.) I think that the crank spins the opposite direction of the S2000's so if you did fabricate a transmission that would work, you'd have to make a new driveline and differential to avoid having 6 reverse gears.
Quick2k
Quick2k
GeneArch
Aug 19, 2002 11:13 AM
