camber problem
Old Dec 31, 2010 | 09:20 PM
philipminge's Avatar
Default camber problem
eyy everyone,
i have an issu with my camber adjustment.
on the left hand side i can get -3.5 degrees of camber. n on the right i can only get -.5 degrees.
originally i they measured the that the right lower control arm was slightly bent, so it was changed and fixed the problem a tiny bit. but i still have the issue. the next thing that could be bent could be the stub axle....
does anyone have any input into what this issue might be. or whats bent. i had the chassis measured for square and its all within spec.
anyone????????
cheers
phil
Old Jan 1, 2011 | 04:07 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Bent knuckle. The wheel was likely hit on the bottom and bent the knuckle positive. Seen it before.
Dreaming_S2k
Nov 9, 2015 04:51 PM
marks_lude
Apr 16, 2010 11:41 AM
bigwhite
Jul 19, 2009 09:16 PM
dan_uk
Jun 5, 2009 06:25 AM
dan_uk
Feb 10, 2009 06:19 AM
