camshaft position sensor connector
so my cousin tried pulling the connector from the sensor with a set of pliers and cracked the connector and now one of the little cables comes loose and causes the car to mark a check engine and also bounces at 3k revs until i turn it off then on and then the check engine stays on but the car runs perfect. basically what im asking is if anyone knows where i can get just the little connector. any help would be greatly appreciated
Well if you feel like digging around to see if you can find it here
http://www.hondapartscheap.com/southbay/js...All&ListAll=All
Otherwise you can try a junk yard?
you can carefully extract the pins, and slide them into the new connector. no cutting needed and car will be like new.
They cannot be purchased separate. They are part of the engine harness.
I have a couple laying around as I have 2 complete harnesses that I use for parts. I just did coil connectors for a guy his lock tabs were broken.
PM me and well set a deal...
incase anyone wants to know i ended up going to the junkyard and finding a similiar but not identical connector and then i joined the wires of he old connector with these. seems to be getting the job done!
