Car #14
Old Nov 1, 2007 | 10:28 AM
truekakaka's Avatar
Originally Posted by duanet85,Oct 31 2007, 07:22 PM
billman, still new to listening to engine sounds. i have a 2000 with 19946 miles on it. i've only had it since around 13500. is there any obvious clues to the broken retainers??
i would also like to know if retainers make a specific noise or sign when they are damaged/broken
Old Nov 1, 2007 | 10:31 AM
animeS2K's Avatar
From reading Billman's posts - no, they don't necessarily make any noise whatsoever if they're cracked/damaged. If they're completely broken, then you're in trouble and your engine go "boom" - valve drops into the cylinder - or am I mistaken here?
Old Nov 1, 2007 | 10:37 AM
CoralDoc's Avatar
And you know that dealer mechanics always follow procedures to the letter, right?
Old Nov 1, 2007 | 11:04 AM
HiPER's Avatar
none. no symptoms.
Old Nov 1, 2007 | 11:08 AM
rugsr's Avatar
how do you check the retainers?
Old Nov 1, 2007 | 01:41 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
No symptoms at all, not even noise.
I've got quite a few threads going about checking them.
Old Nov 1, 2007 | 01:42 PM
TRBOKEV's Avatar
So should we replace AP1 retainers with AP2?
I have close to 50K on my 2002 and only over revved it once accidentally on a missed down shift. My car also is supercharged now and I am thinking of changing out the retainers and keepers. Are titanium ones good or should I just stick with OEM?
Old Nov 1, 2007 | 01:53 PM
animeS2K's Avatar
Titanium will need to be replaced frequently. Go with OEM. Billman suggests AP2 retainers are better.
Old Nov 1, 2007 | 03:11 PM
TRBOKEV's Avatar
Thanks. This can be done with the cylinder head still on by pressurizing the cylinders correct?
I got to find someone here is socal who can do this for me as well as a good valve adjustment.
Old Nov 1, 2007 | 03:23 PM
RED MX5's Avatar
Note that both Billman and I are running the OEM F20C (AP1) retainers.
No need to change the retainers unless you've made a money shift.
If you suspect a money shift, or have a new car that has never had the retainers checked, then you need to do a visual inspection, but that's all.
