Car Bogs advice needed
Old Jul 14, 2010 | 03:06 PM
Dumas2k's Avatar
Default Car Bogs advice needed
I just purchased a 2000 Gwp S2000. I've ran into my first problem as of last night. I was getting in my car and put the car in first gear and as I was driving, It started to bog around 2000-3000k. its a hard bog. But after that it drives fine. The previous owner put a fujita cai and made the fitment smaller so the filter sits right behind the radiator fan. So today i went ahead and changed out the plugs ju a best to see if maybe it was the plugs. It wasn't so then I put on the stock air intake on (the top vacum hose is to small where can i get a bigger one?) This still didnt fix the problem. I did the map whack too. What can it be? any advice? New map sensor? oyea my check engine light came out cause i cant fit one of the vacum hose on.
Old Jul 15, 2010 | 04:14 AM
LINESUPER's Avatar
If that filter is between your radiator and the engine, your running on pure hot air - you will bog and lose power - particularly after the car warms up. If that is the problem, you should relocate the intake. I'm not a fan of the Fujita, but I beleive most people place it low in the front bumper behind one of the side vents.
Old Jul 15, 2010 | 09:47 AM
CapoArgentino's Avatar
Banned
How much do you weigh?
Just kidding!!!!
Old Jul 15, 2010 | 10:17 AM
Dumas2k's Avatar
now the car makes popping noise from exhaust when i idle? any help/?
Old Jul 15, 2010 | 11:45 AM
suzuka-blue-s2k's Avatar
Did you get that vacuum hose on yet? If you still need one, you can get some at autozone. We want to rule out all the obvious first.
Old Jul 15, 2010 | 06:34 PM
Dumas2k's Avatar
i got all the hoses on. now the alternator went out. i was driving and my cluster was dimming eps came on and abs came on....... was this all because my alternator was going bad? i have 117k miles on the S
Old Jul 15, 2010 | 07:30 PM
Hmm..might be possible I suppose. I guess the only thing to try now is to replace the alternator, and see if the problem is still there. If it is, come back and let us know so we can look into it further.
Old Jul 15, 2010 | 07:58 PM
Dumas2k's Avatar
ill be replacing it first thing tomoro morning i hope this all works out..
Old Jul 15, 2010 | 08:56 PM
INTJ's Avatar
I bog at 3200 with a stock setup at 104F.
Old Jul 16, 2010 | 11:41 AM
Downgear's Avatar
The popping at idle is a misfiring most likely. I batted that one for a while and it turned out to be the injectors as they seem to go early in some cases with these cars. You can have them cleaned or even just by a used set like I did. I could not believe that was the problem however it fixed the popping instantly.
