Car Won't Start :(
there could only be three things, alternator, battery or starter. From the clicks, it sounds like your starter is working, so I would suspect it is your battery too, unless you are %100 percent sure you checked the battery and it is fully charged. An easy way to check is to jump start the car, if it starts, then it's not your starter. If all else fails and you need to start the car, just have someone push start it/roll it down a hill in neutral and once you build momentum, pop trans in 1st/2nd gear.
