Car won't start
Old Jan 29, 2009 | 09:46 AM
  #21
SOHCmyDOHC's Avatar
Originally Posted by Burgman' date='Jan 28 2009, 04:34 PM
You can check to see if the fuse is getting power with a test light or a multimeter. On the end of the fuse next to the 7.5 lettering you will see two small areas where you can touch metal with a multimeter probe.
Touch one multimeter probe to the fuse and the other to a good electrical ground on the car. If the ignition switch is good then you will have power at the fuse when the switch is in the on position.
Ok. Gonna have to find my test light!
Old Jan 29, 2009 | 07:37 PM
  #22
damuho's Avatar
Originally Posted by SOHCmyDOHC' date='Jan 27 2009, 01:46 PM
can you simply unplug the alarm?
Aftermarket alarms have a wire harness plugged into the main unit. Try unplugging it and starting the car. If there are more than one wire harness, try unplugging only one at a time - my guess is that the starter kill wires would be thicker than the rest. Also try tapping on the alarm module while starting the car. When the car does not start, try to feel/hear for clicking inside the alarm module while trying to start the car.
The symptoms I experienced with my car are exactly the same as the OP's - first was intermittent non-starts until eventually, it would not start at all.
Old Jan 29, 2009 | 08:07 PM
  #23
tekstar's Avatar
thanks damuho, i hope this works!
just out of curiosity, how did you fix your problem? brand new alarm?
Old Jan 30, 2009 | 08:02 AM
  #24
tekstar's Avatar
okay there were two harnesses plugged into the alarm. i tried unplugging each one, then both, and car still has same symptoms. thanks for the suggestion though.
Old Jan 30, 2009 | 08:18 AM
  #25
dhayner's Avatar
It sounds like you're past this point, but I'd say it's not your battery.
1) Things work normally after waiting a while. Batteries don't suddenly come back without charging.
2) Jumping with cables didn't help.
Old Jan 30, 2009 | 11:07 AM
  #26
bposeley's Avatar
[quote name='Burgman' date='Jan 28 2009, 02:11 PM']Under the dash is a fuse box with 2 rows of fuse.
Old Jan 30, 2009 | 11:15 AM
  #27
tekstar's Avatar
I remember checking that fuse, and it did look fine. Did not bother to swap it though, will try that next. Thanks for the suggestions guys
Old Jan 30, 2009 | 12:29 PM
  #28
damuho's Avatar
I ended up totally removing my aftermarket alarm. I'm sorry it didn't work for you.
I read your original post again and I wonder if it's an important clue that the car shut off while you were parking.
Old Jan 30, 2009 | 07:16 PM
  #29
tekstar's Avatar
took the car to a local member's shop tonight and he found the culprit right away!
it in fact was the alarm good call on that one damuho.
when i checked the alarm this morning i only noticed two wire harnesses coming out of it... both of which were fine. local member noticed there was a smaller third wire harness that had fried. rewired everything up and now everything is good to go
thank you again everybody for all your help!
Old Jan 31, 2009 | 06:32 AM
  #30
damuho's Avatar
I'm glad to hear your S is up and running again!
fastb4ck
Mar 7, 2016 03:38 PM
only9k
Mar 18, 2015 08:52 PM
BBS2KLyN
22
Apr 6, 2013 11:06 PM
bradskee
Dec 25, 2010 02:23 PM
ChineseDelivery
Dec 28, 2008 09:43 AM
