Casper's O2 simulator
I'd like to know to...
After some research and PM's, I've found two possibilities, however, both of the companies seems to be closed. Casper being one of them.
Any new leads would be great!
Bump ^
Bump ^
YES!!!!!!!!!
I even have an extra one which is of the NEWER version.(I used the older one) Though keep in mind that I have an '00 S2000. As such the older ECU does not do some special checks like the '02 and '03 ECU's do.
If you have an '00 or '01 and want a casper mod let me know I will send it out to you.(after it works then you can pay me)
The only one I have found that works is the ECG 5 wire simulator. The 3 wire units just emit a signal without any inputs. The 5 wire unit has 2 sensory inputs from the engine (I think MAP and TPS), so that it can generate a more realistic simulated signal.
S2KEvolution
Jun 20, 2004 03:46 PM
S2KEvolution
May 25, 2004 08:11 PM
