CEL solution
Old Nov 5, 2006 | 03:51 PM
teamxcelap2's Avatar
Default CEL solution
Had a problem with my CEL popping up after installing a JIC test pipe. Wasn't too excited about doing any cutting, welding, or drilling on it. If you don't want to go the fouler plug rout, this works great and is really easy. You wire it into the o2 sensor harness and it sends its own signal to the ecu. I had one of the wires on backward at first but once I solved that, it worked just as it says it will. Make sure you have a multimeter to test the heater wire. I guessed at it and wasted time having to go back and switch wires. The simulator is waterproof so if you can wrap the wiring in heat shrink, then you don't have to worry about it. Here is the website --- www.o2sensorsimulator.com
Old Nov 5, 2006 | 04:40 PM
milkbubble's Avatar
I went with the $4 anti fouler route.. I find it to be the better choice because I didnt have to splice or hack into my harness.. Just my .02 cents.
Old Nov 5, 2006 | 09:56 PM
BlownAP's Avatar
mechanical sel fix, like the fouler are the best choice IMO,
cheap and easy
TRD_Celica
Jan 23, 2013 08:42 AM
c32b
Nov 21, 2012 06:30 AM
mq9-reaper
Jun 9, 2010 04:03 PM
davidd85
Nov 1, 2009 07:50 PM
MegaPower
Jul 29, 2009 09:35 PM
