O2 simulator, still CEL
Old Jul 27, 2009 | 09:45 PM
MegaPower's Avatar
Default O2 simulator, still CEL
my car is 02, stock
I got an O2 simulator from ebay, connected it to ECU
and cut the wire of the O2, connected it to 13ohms 10watt resistor.
It still throw me a CEL after 10-30miles run or 5-20mins.
I reset it and run it, CEL return in 10-30miles, couple times.
CEL P0138
O2 Sensor Circuit High Voltage
I tired 12ohms 10watt, and also 15 ohms 10watt. They dont work as well
Did I connect the wrong wire??
I connected the resistor to two black wires.
The other two wire should be white and blue.
My O2 sensor head already broke, but I dont think it does matter
Old Jul 27, 2009 | 09:53 PM
D Loke's Avatar
I'm not sure why you did all of that when you could of just purchased CEL fix. Sounds like you legit messed something up.
Old Jul 27, 2009 | 11:16 PM
iam7head's Avatar
the newer honda o2 sensor is very sensitive toward slicing and soldering, very often you'll mess them up by redoing the wires, i toasted mine and there's no check fix
Old Jul 28, 2009 | 08:39 AM
MegaPower's Avatar
because i got a broken cat, and broken O2.
I dont want to spend money on a new O2/cat
if I plan to use testpipe later, the electronic O2 simulator will not give you any problem.
Old Jul 28, 2009 | 08:40 AM
MegaPower's Avatar
did you do the wires on the ECU or O2 sensor?
Old Jul 28, 2009 | 09:35 AM
iam7head's Avatar
from the oem sensor pig tail to the o2 sensor itself
Old Jul 29, 2009 | 12:21 PM
MegaPower's Avatar
bump for help?
Old Jul 29, 2009 | 02:20 PM
Slows2k's Avatar
The resistor only fools the heater element DTC's. Your high voltage DTC is from the sensor output from the simulator, not the heater part of the 02 sensor.
The e-bay simulator doesn't work for your car.
Buy an new OEM sensor and a catalytic convertor or a test pipe with the "CEL fix".
You have to have a functioning 02 sensor for the test pipe 02 fix to work correctly.
Old Jul 29, 2009 | 09:35 PM
MegaPower's Avatar
ok, thanks
Got a used OEM cat, and a machincal O2 fix.
Now I need a new O2 sensor....
My money is running away
lol
2000silvers2k
Aug 25, 2016 09:02 AM
FREEK
Jan 9, 2010 01:20 PM
dctor
Jul 16, 2008 10:27 AM
Drkphnx
May 1, 2007 12:33 PM
OCs2k
Jun 16, 2006 05:25 PM
