Cat Delete/Test Pipe
Old Jul 29, 2012 | 03:38 AM
F22Envy's Avatar
Default Cat Delete/Test Pipe
Hey guys
Im stuck between a couple of brands for test pipes for my 06 Ap2, im debating between, Invidia, Megan racing, Berks Technology,and Skunk2 which one do you guys recomend and what size im keeping my oem exhaust in the mean time, im also aware that i going to need the C.E.L adapter, so far i seen Invida with the C.E.L fix going for 87 buck and Megan Racing with the C.E.L.Fix for 98 bucks both are 70mm and burks 70mm as well but for 112 with out the C.E.L fix. and Skunk2 for the same price as berks. which one do you guys recomed me getting fron your Past Expirences. Thanks
Old Jul 29, 2012 | 10:01 AM
CoolGuy094's Avatar
Unless the price difference between the CEL fixed versions and the non-CEL fixed versions is less than $10 then its not worth spending the extra money. You can make your own CEL fix for around 5-10 bucks. I had the Invidia test pipe, the non-CEL fix version, and did my own CEL fox with the Autozone spark plug defoulers. It worked great and never had a CEL. I sold it to get a high flow cat to be STR legal in Autocross.
I would say buy the least expensive one of the ones you listed, and the smaller diameter size to mate up with the stock exhaust better, and do your own CEL fix.
Old Jul 29, 2012 | 12:40 PM
F22Envy's Avatar
cool man thanks looks like ill be going with the invidia 60mm test pipe
Old Jul 29, 2012 | 09:04 PM
TougeS2k's Avatar
No, go berk!
Old Jul 30, 2012 | 04:49 AM
Reckon's Avatar
In essence, a TP is a TP and they should all be similar. Differences will be in the quality, but with the brands you listed that shouldn't be an issue. The spark plug anti fouler trick works but you have to make sure you have the tools to drill out one of them to get the O2 sensor to fit. Otherwise, it might be worth the cost of getting a TP with CEL fix. I did, having gotten the Invidia 70mm with CEL fix and even then I had to add one spark plug anti fouler to the CEL fix adapter to get it to work right. See if you can find one used from a member in your area - that would be your best price and you will have some first hand knowledge from the previous user.
Old Jul 30, 2012 | 06:35 AM
ga s2000 man's Avatar
I have a berks and never had any issues. Go berks
Old Jul 31, 2012 | 09:04 PM
davidc1's Avatar
FYI, it's "Berk"....no "s".
Old Aug 1, 2012 | 10:32 AM
s2000maniac's Avatar
FYI, it's "Berk Techonolgy" ...... no "berk"
Old Aug 1, 2012 | 11:26 AM
CoolGuy094's Avatar
Originally Posted by s2000maniac
Originally Posted by davidc1' timestamp='1343797489' post='21904061
[quote name='ga s2000 man' timestamp='1343658925' post='21898969']
[/quote]
FYI, it's "Technology" ...... no "Techonolgy"
lol
Old Aug 1, 2012 | 11:30 AM
Bugsy's Avatar
They do perform.
Sadly...
They all smell terrible.
