Cat oxygen sensor appearance?
Old Mar 16, 2017 | 04:17 PM
jwfisher's Avatar
Default Cat oxygen sensor appearance?
What should an oxygen sensor look like? I am chasing down a P0420 and pulled the o2 sensor out of the cat.
Note the appearance, no shield/cage and it looks like a layer was burned off.
Thx!
Old Mar 16, 2017 | 05:27 PM
gptoyz's Avatar
yes you might be missing something:
Old Mar 16, 2017 | 05:48 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Even though the outer protective cage is missing, that o2 sensor is fine. If it wasn't, other codes would set. P420 is not related to a broken sensor cage.
Put a spark plug spacer on it and you're done. Not only will it cure your P420, it will protect the sensor element for life.
Adding a single spacer in the cat is a good proactive measure even on a car with no problems or codes, as the cat media breaking loose is extremely common. The spacer will protect it.
Old Mar 17, 2017 | 07:13 PM
jwfisher's Avatar
I like that idea... this is a great solution. Question - these "o2 sensor extenders" - lots of choices are available. Are they all 18 x 1.5 threads?
And, yes, the old converter has had the catalyst break loose inside, it's moving around and causes a death rattle when idling.
s2kbtos
Dec 17, 2017 03:08 PM
RichSouth
Mar 18, 2013 01:35 PM
davidc1
Dec 19, 2010 08:44 AM
s2kattack
Sep 1, 2009 03:32 PM
nicku
Oct 2, 2006 05:54 PM
