CEL after test pipe and exhaust install
Old May 22, 2012 | 07:55 AM
spdoran's Avatar
I just installed the invidia test pipe with CEL fix also and just for security added a T1R oxygen sensor simulator/CEL Fix and everything appears to be just fine no CEL after a slow warm up and a full drive. I highly recommend the invidia setup.
Old May 22, 2012 | 01:34 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I've had invidia test pipe with CEL fix fail to keep the light off. Still had to add a spacer on 00-05 cars.
I have no solid answer for 06-09 yet.
Old May 23, 2012 | 04:18 AM
Biohazard's Avatar
I found that the angle defoulers keep the cel from occuring. 2008 CR no issues. you can get the angle defoulers from club rsx.
Old Aug 30, 2012 | 04:40 PM
uLmighty's Avatar
I jst put a invidia on my 08 cr with anti-fouler from autzone and it was fine for like 50-100miles? The cel came on today
Old Aug 31, 2012 | 10:19 AM
Billman250's Avatar
Top Answer: 1
Your CEL came on because the CAT monitor finally completed, failed, and commanded the light on for P0420.
Did you use the angled sensor? I have not had a chance to try it for myself yet.
Old Aug 31, 2012 | 10:23 AM
icemans2k02's Avatar
Also when you do the trick as mentioned. Make sure you only drill ONE of the foulers not both. That way the opening will not be very big.
ap2_lumpy
Jul 12, 2009 01:43 PM
H2kBBAP2
May 2, 2009 09:26 AM
04ssonbl
Dec 21, 2008 07:04 AM
freshs2k
Nov 29, 2005 07:01 PM
