CEL came on
Old Mar 2, 2010 | 01:21 PM
Rowan's Avatar
Default CEL came on
Hello S2Ki,
I am running into a bit of a problem with my car, '07 S2k. Just to give a quick history, the car's CEL came on when it had 47,xxx miles. I scanned it and got the code P0139 (slow response 02 sensor, secondary). Honda replaced it for free under the 50K powertrain warranty. So I was a happy camper after that.
Now fast forward to 52,xxx miles and the CEL came on again. I scanned it and got the same code again. Did anyone else experience this? I am not worried about it since Honda will replace the part for free (part came with a 1 year -12K mile warranty). I have since reset the code to see if it does come back within a few drive cycles. My guess is that the CEL will come back if the malfunction is indeed valid. I'll find out soon enough. Anyway, my concern is there might be something else triggering the 02 sensor to fail. Why would the new 02 sensor fail so quickly after only 5,xxx miles? Any thoughts?
I do not have an aftermarket exhaust now but i did have an HKS from 10K to 30K miles.
Thanks for reading and I appreciate any feedback.
-Rowan
PS. I tried the search and it was down so I decided to write this up.
Old Mar 3, 2010 | 09:45 AM
Crisgo's Avatar
I'd say either a bad connection(loose or corroded pins) or another bad sensor. Odd if that is the case. Are you running a different type of fuel or any kind of exhaust leak?
Old Mar 3, 2010 | 03:29 PM
jamest16748500's Avatar
they should replace it there is a mandated law 8 years or 80k which ever is first if the cat is bad that is.
any q's go here http://www.epa.gov/oms/consumer/warr95fs.txt
Old Mar 3, 2010 | 05:58 PM
Slows2k's Avatar
8/80 federal emissions does not cover 02 sensors, only PCM's and catalytic convertors. CA emission warranty is different.
If you are under 12months/12K let them replace it again.
Old Mar 3, 2010 | 09:31 PM
Rowan's Avatar
thanks for the input guys. so far, the CEL has not come on after 4 drive cycles so i'll leave it alone. hopefully if it does come on, it's within the next 7,xxx miles so i can get it replaced by the dealership for free. :-)
Old Mar 3, 2010 | 09:50 PM
Ape-x's Avatar
if u hav an aftermarket cat or no cat u may want 2 look at a celfix there cheap as and easy 2 install
Laguna_S2K
Aug 28, 2014 10:01 AM
sybar
Oct 27, 2010 01:03 PM
DELAWARES2K
Sep 16, 2009 05:10 PM
JUSTINTHECOASTIE
Jul 20, 2009 06:50 PM
