CEL came on after KN install
Old 12-28-2011, 02:00 PM
shadow11's Avatar
Default CEL came on after KN install
Ok so I just finished installing my KN intake I got for Christmas. Hop in start it and let it warm up. Once its warm I head out and do a few redline runs and I only get about two miles away from my house and the car suddenly starts shaking and it won't rev past 3k and a cel comes on. I drive it really slow to get it home and open the hood and it has this weird smell. All the hoses and everything are hooked up right so I don't know what the problem is? A tried to read the code with my tuner for my truck but it said it didn't have any codes. Anybody have any ideas? 04 Ap2
Old 12-28-2011, 02:07 PM
shadow11's Avatar
Oh and when i try to start it it takes like an extra second or two to start than it normally does.
Old 12-28-2011, 02:08 PM
rob-2's Avatar
You didn't re-connect something.
I cannot figure why you'd make a mod and than put the car at it's limit right away.
Old 12-28-2011, 02:14 PM
shadow11's Avatar
Everything is connected right. I didn't beat on the car after I installed it. Only did 2 7k runs
Old 12-28-2011, 02:23 PM
trAP2's Avatar
if everything is connected right maybe u need to look into something else especially since you did a few runs. Also you said redline runs not 7k runs
Old 12-28-2011, 02:24 PM
rob-2's Avatar
Well the air intake isn't doing anything to the car. You could run without an air intake. Go over your work.
Me personally, I would have reset ECU and re-learned idle. Taken it for a short drive, shifting around 4K. But that's me.
Old 12-28-2011, 02:25 PM
axus19's Avatar
Did you reset your ECU? Same thing happened to me.Just unplug the battery for like a minute and turn it back on and let it idle for like 5 min with the hood closed and go for a cruise after.The ECU needs to relearn itself
Old 12-28-2011, 02:27 PM
dnace's Avatar
Make sure the two small hoses by plastic fuel rail cover heard a few get a cel from that
Sent from my DROID X2 using Tapatalk
Old 12-28-2011, 02:55 PM
shadow11's Avatar
Ok I figured it out. One of the plugs near the intake had one of its wires pulled out of the plug. Put the wire back in and stew runs perfect. I must have somehow pulled the wire out when I was taking the old hoses off. Had we worried there for a few minutes lol. Now time to install my heated seats
Reckon
09-16-2010 02:48 AM
AP2DRIFTER
09-04-2008 03:21 AM
WeezyBaby
03-01-2007 06:55 PM
mcomer
01-29-2004 01:36 AM
FF2Skip
02-21-2003 11:13 PM
Quick Reply: CEL came on after KN install
