CEL issue, Speed sensor
Old Mar 3, 2013 | 01:51 PM
Vinsfeld's Avatar
Default CEL issue, Speed sensor
My speedomter will sometimes not work, and then a CEL came on, I took my car to autozone, and they diagnosed it as a speed sensor failure. I am thinking it has something to do with my Yellow Jacket, but I checked and all my wires appear connected, and the yellow jacket itself (modifry version) has the self diagnosis light showing that it is connected and functioning. Anyone have any idea what else it could be?
Old Mar 4, 2013 | 01:02 PM
Vinsfeld's Avatar
bump
Old Mar 4, 2013 | 01:14 PM
MM3Kwolik's Avatar
Probably your actual vehicle speed sensor then I would guess. It's located on the side of the transmission.
Old Mar 4, 2013 | 03:02 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Check the ground wire on the back of the cylinder head. It is directly related to speedometer issues.
Old Mar 4, 2013 | 03:27 PM
Vinsfeld's Avatar
Is there an easy way to access the ground on the back of the head? I tried the other day just to see if I could look behind the head but there was no room from the top. I am guessing there is more access from underneath?
Old Mar 4, 2013 | 03:30 PM
Billman250's Avatar
Top Answer: 1
top access only. get a mirror to locate it.
Old Mar 4, 2013 | 03:41 PM
Vinsfeld's Avatar
Ok I will, once I locate it, if it looks loose, what would be the best tool to tighten it? Just a regular wrench? I hope this is the case. Thanks for your help.
Old Mar 4, 2013 | 03:54 PM
s2000maniac's Avatar
Does your Milage still work?
Old Mar 4, 2013 | 04:05 PM
Vinsfeld's Avatar
When the speedometer doesnt, then the odometer doesnt as well.
-Matt
Mar 4, 2017 09:15 AM
huichex
Jan 8, 2014 03:14 AM
Jonzyy
Aug 25, 2012 11:50 PM
Princeneo
May 20, 2012 12:24 PM
OCs2k
Jun 16, 2006 05:25 PM
