CEL light not coming on when it should be on, no codes despite misfire
Old May 29, 2016 | 09:27 AM
weekendwarrior44's Avatar
Banned
Default CEL light not coming on when it should be on, no codes despite misfire
I've ran into a strange issue I've never seen or heard of before. My CEL light isn't working even when I first turn the key to the on position. I know that can probably just be the bulb but what I find strange is that I know for a fact I should have misfire codes and there is none, I'm pretty sure the ECU is also communicating with my scanner slower than it used to. I also have a misfire at low rpms when giving it a little gas and on take off and sometimes the car idles perfect when pulling upp to a light and occasionally the revs will slowly drop out before stalling. Could my ECU be out? I just recently fixed a short in my headlights that was causing my trunk, door locks and running light fuses to blow. Seems like my CEL turned off at the same time that issue had started. Couldn't find my same issue here in the forums. Thanks in advance guys.
Old May 29, 2016 | 10:05 PM
Soviet's Avatar
You can certainly have a misfire without having a CEL I can personally attest to this and so can many frustrated people in the misfire thread haha.
How do you know for a fact that you should have misfire codes?
Has your CEL light ever worked? I bought a car that conveniently had the SRS bulb pulled... I would imagine someone sketchy might want to pull the CEL light when selling a car.
Old May 31, 2016 | 07:39 AM
Banned
i know for sure because it doesn't come on when i turn the key and it was always on until the other day it just turned off all of a sudden when driving
Old May 31, 2016 | 11:09 AM
Soviet's Avatar
You should actually scan the car for CEL codes. The CEL and go on and off depending on what is wrong...
Old Jun 1, 2016 | 08:36 PM
RickyLee's Avatar
valve adjust. if it still misfires look for vacuum leak
Old Jun 2, 2016 | 10:00 AM
Dead Serious's Avatar
My car had the same drive-ability issue when a coil started going bad. Cant comment on the CEL though besides it never coming on during my intermittent misfire issue.
Calamari
Sep 15, 2010 03:26 AM
GTS Jeff
May 31, 2009 09:43 PM
07RioS2k
Oct 9, 2008 07:50 AM
Dembo
Dec 17, 2006 01:04 AM
RaDZio
May 4, 2004 02:24 PM
