CEL P0600: Multiplex control system error
Old Sep 3, 2009 | 03:44 PM
JS2k.com's Avatar
Sponsor
Default CEL P0600: Multiplex control system error
Hey guys,
I would google some more but I'm in the middle of a road trip and I got a CEL.
The CEL is P0600 and the autozone printout says it is a multiplex control system error. I have no clue what this is.
Thanks.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Sep 3, 2009 | 03:57 PM
siik_ap2's Avatar
multiplex is the fuse box. under dash
Old Sep 3, 2009 | 06:49 PM
Slows2k's Avatar
Autozone's scanner can't define the code correctly.
Old Sep 3, 2009 | 06:51 PM
Mark355's Avatar
Google isn't helping much with this one. I keep getting references to "Serial Communication Link Malfunction." Is that the OBDII connector or something?
Old Sep 4, 2009 | 04:40 PM
terahertz's Avatar
my iphone app says it's a "Serial Communication Link (DataBus) Message Missing" whatever that means. lol
Old Sep 4, 2009 | 04:52 PM
Slows2k's Avatar
Take it to a shop that can define the DTC correctly.
Old Sep 4, 2009 | 08:30 PM
scors2's Avatar
P0600 Serial Communication Link Malfunction. This code is usually assorted with communication between ecu's. If you can get a hold of a scanner see what ecu's are not assessable. In example engine, abs or air bag computers. usually the one with no communications is the problem. You may or may not receive a second code that my point to the ecu with the problem. Or you could just have a blown fuse.
Old Jul 4, 2010 | 04:21 PM
mads2k08's Avatar
Originally Posted by JS2k.com,Sep 3 2009, 04:44 PM
Hey guys,
Thanks.
My CEL threw a P0600 too. It happened when I was in the last hour of a 6 hour drive. A google search says P0600 is a serial communication link failure. Furthermore some more searches revealed that other S2k members have received this CEL. Apparently it's due to a bug in the ECU software - the ECU throws a P0600 when the ignition is on for 4 or more hours. Weird!
Read this:
P0600 Problem
How did you resolve this issue? Anyway for the dealerships to fix this? I have HondaCare.
Old Jul 16, 2010 | 01:16 PM
mads2k08's Avatar
~bump
Old Jul 17, 2010 | 02:06 AM
Siepel's Avatar
FYI: P0600 = Multiplex Control System Troubleshooting
per Honda Service Bulletin 03-020 (all models except Honda Passport)
so Autozone is not that far off
