CEL P1415
Old Jan 21, 2014 | 11:04 AM
  #21
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Had a customer come in with an Izze kit and P1415 code.
His 15A "keyless" fuse was blown, top right row of under-dash fuse block.
If you have this code with your Izze kit, check the operation of your TRUNK RELEASE button in the center glove box.
Ihe Izze kit and trunk release button share the same power source.
So, if you have an Izze Kit P1415 and a inoperative trunk release button, rest assured that 15A "keyless" fuse is blown.
This brings all my Izze Engineering Air Pump Simulator customers back to 100% reliability record as far as this kit is concerned.
I just did a new kit this morning and they have a new look/upgrade. Highly recommended
Old May 2, 2014 | 02:38 PM
  #22
andylexo's Avatar
Just installed the Izze Kit. Followed instructions to the T.
P1415 Low voltage popped up. Trunk release still works. The fuse is not blown.
My battery was relocated into the trunk before I purchased the car.
Could that be the reason it's causing low voltage?
Any answers help.
Edit/Update.
Rechecked the wires. The supplied crimps worked on one wire. The rest, barely a scratch lol.
Caleb reassured me the relocated battery shouldn't cause any problems and it didn't.
Everything is good after fully tapping the wires. No more CEL. Yay!
Old Oct 16, 2015 | 10:09 AM
  #23
Jogabs39's Avatar
Hi Caleb I'm gonna order tomorrow okay
Old Nov 16, 2022 | 05:37 PM
  #24
Cory M's Avatar
Old thread but I found it helpful. I had the same code. It only started coming up after I had to replace a dead battery. Found that my 15 amp keyless entry fuse was blown as well. Replaced the fuse and all good.
H!cks
Nov 3, 2015 01:47 AM
legin_k
Nov 6, 2009 01:19 PM
r8byb
Apr 15, 2009 09:17 AM
kylemonster85
Aug 31, 2008 12:12 PM
TheCarGuy2021
Sep 8, 2006 12:27 PM
