CEL - Secondary Air Injection System
Old Mar 4, 2009 | 04:28 AM
nightcrawler7188's Avatar
Thumbs down CEL - Secondary Air Injection System
i think it was P0411 or something like that. how do i get rid of this code? i cleared it to see if it would come back and it did. i have my air pump hose hooked up to the aftercooler on my comptech supercharger like it should be. i've been supercharged for over a year and i've never gotten any CELs other than a misfire (burnt coil pack) and knock sensor malfunction (the old knock sensor broke).
Old Mar 4, 2009 | 04:41 AM
sparrow's Avatar
you gotta check the pump itself and every inch of the hosing... if all those are in proper condition then go from there...if you search you will see that sometime the housing of the air pump itself has cracked/open in some way and therefore it may turn on but not force enough air through the hosing.
Old Mar 4, 2009 | 05:10 AM
my car does have some insane vibrations that rattle frikkin o2 sensors and BOVs loose...ughhhhh i don't wanna take off my damn bumper again lol
Old Mar 4, 2009 | 04:11 PM
Jynxer19's Avatar
Did you check the vacuum lines? I had a loose line rub against a pulley, wore a hole, CEL came on same code. Fixed the line and CEL went off itself same day.
Old Mar 4, 2009 | 06:17 PM
Utah S2K's Avatar
Not sure on an FI car.....if it was NA then I would say 100% it was the little white check valve being backwards. Have you done any service recently where you may have reversed the check valve? You say you "cleared the code". If you did this the proper way as opposed to disconnecting the battery you can do an OBD-II dump and look for pending codes.........most people unknowingly diconnect to clear and lose pendings. My guess is you either have a reversed check valve or it is fouled. I have a lot of experience with Seondary Air. If its not the valve or a rubbing line give me a PM.
Utah
Old Mar 4, 2009 | 08:25 PM
^^thanks, will do as soon as i can get around to it. i haven't done any maintenance lately and my lines have been correct from day 1 that the SC was installed last year. this code really came out of nowhere so i'm thinking maybe the pump itself failed or perhaps a rubbing line has a hole. i used an OBD2 scanner to clear the code, not just disconnecting the battery.
dsthez
Jun 24, 2015 02:24 PM
dagle
Jun 12, 2015 12:39 PM
project*stealth
May 6, 2013 08:36 PM
rhysmate
Jan 23, 2013 05:52 PM
LubedKoala
Feb 5, 2008 03:17 PM
