Change transmission fluid or overkill
Originally Posted by negcamber,Mar 11 2009, 09:58 AM
Use the latest Honda MTL from the dealer...it is the best I've used.
Don't buy the diff oil from the dealer...they will likely give you diff oil for the CR-V, which will kill an s2k diff.
Originally Posted by sentravq,Mar 11 2009, 01:59 PM
So the rear diff oil listed in the Honda S2000 factory mannual is bad for our cars. Arent they suppose to use it as listed on the mannual? Is the oil listed in the mannual bad. Just wondering why would they use it if its gonna hurt the diff.
and as far as your temp being at 48%, it should be 8 bars i believe on 2004s and up
crv vtm gear oil isn't what is recommended in the manual. Most dealers don't carry s2000 gear oil, so when you ask for diff fluid they will give you the one they have on hand, which is wrong.
I called the dealer ask them if they had any rear diff fluid available to buy . He told he has some but in a 90 weight but its in bulk and cant sell it in individual amounts and he suggest i go to an auto store to get a 90 weight rear diff fluid.
