Changing door panel inserts.
Old Sep 21, 2005 | 06:58 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Default Changing door panel inserts.
O.K.the FAQ,has a detailed "How to remove door panel".
Once this is done,how do I remove black door inserts,and reinstall red ones,without breaking anything,and doing a nice,good looking job?
I read somewhere,I will have to use some kind of glue;don't want to smear it all over the place;what kind of glue,and where to get it?
Old Sep 21, 2005 | 07:03 PM
sebrings2k's Avatar
No glue needed.
Take your time. There are some O-clips that can break if you try to force 'em out. Otherwise the panels are secured by a bunch of screws.
I used a leather cleaner/conditioner while the panels were was off.
Shouldn't be more than a 2 hour job max.
Old Sep 21, 2005 | 08:07 PM
Thank's.
You sure about no glue?
I read,in a post,that the inserts were glued to the door panel!!!
So much the better if no glue is needed !!!
Old Sep 21, 2005 | 08:30 PM
sebrings2k's Avatar
If anything some double sided tape?
My car (MY02) door panels came on and off without any glue.
There is foam backing strips that surround a cup like area that seems to provide structural rigidity for the door panel. Some of that stuff will be torn and pulled off in order to remove the insert.
Old Sep 22, 2005 | 03:23 AM
hygiene boy's Avatar
No glue just screws. Been there done that a few times.
Old Sep 22, 2005 | 05:37 AM
FF2Skip's Avatar
Just a bunch of screws. Very simple task actually.
Old Sep 22, 2005 | 05:39 AM
Thank's for the infos.!!!
Emil.
abroke1
Jul 12, 2013 04:33 PM
SEA2SJK
Nov 29, 2009 12:08 AM
RL428
Dec 6, 2008 06:03 PM
nearwater4me
Apr 5, 2007 04:37 PM
Bandit_287
May 15, 2006 01:30 AM
