changing motor mounts
Old May 13, 2009 | 12:48 PM
goldenfri's Avatar
Default changing motor mounts
I am going to be changing out my engine mounts soon. Is it ok to support the engine with a 2x4 and a floor jack under the oil pan? or is there a better way to do it?
Old May 13, 2009 | 01:31 PM
DER MotorSports's Avatar
Damn dude - don't know if that's a good idea. Why not rent an engine crane?
Old May 13, 2009 | 01:45 PM
Bugs2k's Avatar
change one at a time. suport engine with jack with block of wood between it and oil pan should be fine.
Old May 13, 2009 | 02:00 PM
arkkornkid's Avatar
Old May 14, 2009 | 05:52 AM
goldenfri's Avatar
Cool, that's how I was planning to do it. Just wanted to double check that there wasn't anything wrong with that. Thanks
Old May 14, 2009 | 05:57 AM
Bugs2k's Avatar
anytime
Old May 14, 2009 | 07:05 PM
Neutered Sputniks's Avatar
I'm going to go with DER on this one. I would suggest using an engine crane. They're not that expensive (to rent or buy) - definitely less expensive than oil pan damage would be...
Old May 14, 2009 | 07:19 PM
Slows2k's Avatar
It can be safely done with a block of wood under the pan. It's actually easier to install some headers by removing the right engine mount and raising the engine slightly.
Old May 14, 2009 | 07:57 PM
myblaks2k's Avatar
that's exactly what i did yesturday. it worked perfectly for me.
skool u
Jun 11, 2018 10:41 PM
shibby2000gt
Mar 24, 2013 06:29 PM
SoCalIsMyLife
Aug 7, 2008 04:42 PM
Lice Locket
Feb 27, 2007 07:08 AM
