Changing passenger window on 95 Civic
Old Dec 29, 2001 | 05:04 PM
krazik's Avatar
Administrator
Default Changing passenger window on 95 Civic
I am assuming this is something I can do myself. Is this true?
Any tips?
Old Dec 29, 2001 | 06:12 PM
XTC at 9K's Avatar
for starters, you should at least know how to remove the door panel. after that there are two bolts w/ 10mm heads that hold the door window to the regulator. to access these bolts, you have to lower or raise the window to a certain position-lining it up with the holes in the door.
Old Dec 30, 2001 | 08:09 AM
Tugz_S2K's Avatar
Banned
Its very easy to do, there are only two 10mm bolts that hold the glass to the window regulator. Remove the door liner, Peel back the vapor barrier, line up the window bolts with the installation holes in the door, un-bolt the window, and carefuly remove....Give me a PM if you need assistance. Ill be happy to help
Peace
bnag0
Jul 27, 2011 04:00 AM
damn_son_s2k
Aug 18, 2010 01:32 PM
vstypicals
Apr 23, 2010 08:03 PM
macr88
Body
Jan 14, 2010 09:43 PM
vvs
Aug 1, 2008 02:30 PM
