How to replace window regulator?
Old Apr 15, 2010 | 01:25 PM
vstypicals's Avatar
Default How to replace window regulator?
My driver's side window just fell inside the door on my way home from work yesterday. I tried searching, but I didn't really see any info. Any ideas on what happened or what's broken, and how to fix it?
UPDATE 1: I removed the door panel, and it looks like the cable snapped. I guess I have to buy a new window regulator. Anyone have a DIY to replace this?
UPDATE 2: I have the old window regular unbolted, but I can't get it out and get the new one in. I guess I have to remove the metal plate to get full access?
UPDATE 3: I got the new window regulator up and running. Had to take the window out first.
Old Apr 15, 2010 | 09:40 PM
hippo and dog's Avatar
there are roughly 5 bolts holding the window up. maybe those bolts got loose. take off your door panel and check to see if those are still connected.
there is a screw on the interior latch/lock cup area, the two screws in the top and bottom of the handle, and i think one to the far top right of the panel.
if you take those off, pop it off from the bottom, then you have access to it.
Old Apr 15, 2010 | 09:53 PM
sillyboybmxer's Avatar
or the cable snapped.
happened on my old ep3 civic,.....pretty simple to replace once you pull the door panel off and see whats going on.
Old Apr 15, 2010 | 11:18 PM
vstypicals's Avatar
Sweet. I'll take a look at it tomorrow night.
Old Apr 16, 2010 | 10:53 AM
petawabit's Avatar
happened to me. the cable snapped. ended up just getting a whole new motor/assembly from the dealer for like 200 bucks
Old Apr 16, 2010 | 11:15 AM
vstypicals's Avatar
Is that the only option if the cable snaps (to replace the whole motor/assembly)?
Old Apr 16, 2010 | 01:10 PM
dammitjim's Avatar
You should be able to use a 2x4 to prop up the window.
Old Apr 17, 2010 | 09:31 PM
vstypicals's Avatar
UPDATE: The cable snapped. Anyone know how to go about replacing the window regular? It looks pretty cramped in there. I'm not sure how I'm gonna get my hands inside. The whole to get access to the window isn't very big.
Old Apr 23, 2010 | 08:03 PM
vstypicals's Avatar
UPDATE: I have the old window regular unbolted, but I can't get it out and get the new one in. I guess I have to remove the metal plate to get full access?
Anyone know how to remove that metal plate?
turbosix
Nov 20, 2011 12:46 PM
damn_son_s2k
Aug 18, 2010 01:32 PM
Elistan
Jan 20, 2009 11:18 PM
Mugen112
Feb 29, 2008 08:51 PM
VTEC4-2
May 12, 2004 02:54 PM
