Chassis lubrication
Old Jun 12, 2010 | 12:18 AM
RsxFlyBy's Avatar
Default Chassis lubrication
I have done some extensive searching on this site about the lube points on the chassis and suspension but have come up short. I found one thread that look promising but quickly went off topic with lots of "lube" innuendo. I have purchased some 3M wet silicone type lube and would like to know where I should apply this. Pictures would obviously be ideal and any advice on the application procedure. Thanks!
Old Jun 12, 2010 | 02:36 AM
INDYMAC's Avatar
I'm not aware of any chasis lube zerc fittings, if that is what you are looking for. If you do find some, probably a NGLI 2 general purpose grease would be appropriate to use.
Here is an old post by the iconic Road Rage that addresses the issue:
https://www.s2ki.com/forums/index.php?showt...0&#entry3152338
Old Jun 12, 2010 | 08:21 AM
jeggy's Avatar
when i worked at honda, the only thing/place i lubed during maintinence services were: door hinges, hood latch, hood hinge........ thats all i can remember right now
Old Jun 12, 2010 | 10:35 AM
crank's Avatar
i lube ALL rubber bushings with NON petrol based silicone !
Old Jun 13, 2010 | 01:05 AM
SpitfireS's Avatar
The most important chassis parts that need lubrication - or better: anti seize! - are out of reach: the alignment bolts.
Unfortunately
Its not a bad thing to keep rubber boots "lubed" with silicone, but on my MY'00, daily driven in all kinds of weather including salty roads, not 1 rubber boot has failed on me yet.
Old Jun 13, 2010 | 08:42 AM
crank's Avatar
Unfortunately
ya, i also keep anti seize on the front and rear subframe bolts !!
Old Jun 13, 2010 | 11:05 PM
RsxFlyBy's Avatar
Is there any cleaning procedure before applying lube? I have really never done this before and not entirely sure what I should be looking for.
Old Jun 13, 2010 | 11:10 PM
Seattle2k's Avatar
just wipe of anything that's dirty.
Old Jun 14, 2010 | 10:57 AM
crank's Avatar
[QUOTE=RsxFlyBy,Jun 13 2010, 11:05 PM] Is there any cleaning procedure before applying lube?
Old Jun 14, 2010 | 02:02 PM
Boofster's Avatar
I also recommend keeping all rubber "wet" as much as you can.
This is especially important for hotter than fawk states like AZ. Rubber is the first thing that will start to go brittle otherwise. It will fall apart when it dries up.
RichwiththeS2000
Feb 17, 2013 07:07 AM
zzkamikazezz
Oct 15, 2011 12:06 PM
amdaman
Jan 3, 2010 06:13 AM
HonCBRf2
Nov 6, 2008 06:57 PM
juno1
Mar 28, 2008 09:38 PM
