Check Engine Light ?
Old Sep 19, 2001 | 12:48 PM
notstr8's Avatar
Default Check Engine Light ?
Hey whats up everybody, I seem to be having a little problem with my car for the past 3 weeks its check engine light has been coming on after Honda resets it my car is again at the dealer (4 time this month) today and all I get from them is that nothing is wrong that its a false "evap" code whatever that means ? Has anybody had a problem like this ?
Old Sep 19, 2001 | 01:30 PM
joe_s2k's Avatar
You might want to get the actual ECU CODE the next time you take it to the dealer. I can't believe that they are clearing the code and sending you out. Eventually, something is going to be affected. Try and document each visit with your dealer if you can. You might need it when something goes wrong and they blame you for not getting it fixed earlier.
PS. Do a search on "check AND engine" for more info.
Here's one
Evaporator Code (again)
Old Sep 20, 2001 | 03:51 PM
Utah S2K's Avatar
No need to return to the dealer........
The heater control panel has a self diagnostic function:
1) Set the mode control dial to the vent position
2) Turn the ignition switch ON (II)
3) Within 5 seconds of turning the ignition switch on, press the recirculation control switch (This switch has a car with a circular arrow and a small light on it to the right of the steering wheel) the required number of times depending on the recirculation light status.
A) If the indicator light is ON, press the recirculation control 5
times.
B) If the indicator light is OFF press the recircualtion control
6 times.
The recirculation light will come on for 2 seconds, the blink the diagnostic trouble code (DTC) to indicate a faulty component. If no DTC's are found, the indicator light will not blink after the initial 2 second light.
Run this test and I'll tell you what you need to replace......
Utah
Old Sep 20, 2001 | 03:53 PM
Utah S2K's Avatar
.....should blink from 0-4 times, with 1-2-3-4 indicating faults.
Old Sep 20, 2001 | 04:43 PM
punisherS2000's Avatar
well i'm having check engine light problems too
after reset the light come back next day
well my friend check and it say problem with air system somthing
but nothings wrong with the car~
the engine check light bugs me i don't know what i have to do
well i didn't had any problems after i put Injen intake it was ok for 2~3week and one day early morning i start the car and engine light came on. since then don't want to go away
hey guys what should i do~ help me out please~~~
Old Sep 20, 2001 | 06:30 PM
joe_s2k's Avatar
[QUOTE]Originally posted by Utah S2K
[B]No need to return to the dealer........
Old Sep 20, 2001 | 06:44 PM
Utah S2K's Avatar
[QUOTE]Originally posted by joe_s2k
[B]
Utah,
That's some good information, but I still feel that the dealership should perform the diagnostics on the car while it is under warranty.
Old Sep 20, 2001 | 06:46 PM
Bill L's Avatar
I think I might have missed something. I appologize if this is a redux. How do we access the codes? Can we hook up laptops, computers, etc? What's the software?
Old Sep 20, 2001 | 06:55 PM
Utah S2K's Avatar
[QUOTE]Originally posted by punisherS2000
[B]well i'm having check engine light problems too
Old Sep 20, 2001 | 06:58 PM
Utah S2K's Avatar
https://www.s2ki.com/faqs/showfaq.php?threadid=17414
Utah
