Check Engine Light
I doubt that the CEL is caused by the over rev .... i in my case did a couple of over revs during my driving where accidently switching to lower gears and hitting the rev limiter. That did not kick a CEL. i run my S2K with a CEL for over 2 months now and i checked my code to find it was P1414 02S HEATER CIRCUIT (B1/S2) ..... i was told that it doesn't do any harm to my car and to replace the sensor will cost over $200 ... so i chose not to
only harm i will not know if there is another problem with my car because my CEL is already on.
Point of my story there is no use assuming and no one will know y the CEL kicked in, u need to get the code.
only harm i will not know if there is another problem with my car because my CEL is already on.Point of my story there is no use assuming and no one will know y the CEL kicked in, u need to get the code.
Originally Posted by RASHID007,Aug 27 2005, 02:23 PM
As far as my gas cap goes there must be a problem with it then because no matter how many clicks I tighten it I find it one quick twist away from opening the next time I go to fill up.
You're all right, I'll just get the codes because guessing doesn't make any sense.
As far as over-revving I did start at 6000rpm in 2nd gear and shift at 9000rpm to 3rd so if you can't over-rev that way then I did not over rev.
Originally Posted by RASHID007,Aug 31 2005, 09:23 PM
I drove the car around for a few days with the CEL on and now it's gone. Just turned off. Maybe it was the gas cap but pulling the fuse wasn't enough to clear it?
Still guessing? Should have pulled the codes. Now, you may never know what was wrong. Next the CEL comes on, PULL THE CODES AND STOP GUESSING!
This is why I have the RacerData thing. It pulls codes and lets you clear them. If you don't know what the code is you shouldn't be driving all over the place with it on as you don't know if your causing more damage.
It amazes me that people have a cel light on and drive around without knowing what the problem is. You can go to Autozone and they'll pull codes for you if you don't want to buy a scanner or some sort.
dang the same thing happend to me. my friend hooked a little comp to the czr and told me it was the Gas cap going bad and that it keeped opening up... but it was really tight so i dont know. i will get the code tomorrow and see cause even tho i know my car is fine, i cant stand that litle light...it drives me nuts.
