Check Engine Light
Old Jan 25, 2007 | 03:21 PM
Mister Jew's Avatar
Default Check Engine Light
Hey,
Well i had some pieces laying around with an old K&N filter so i threw it on my 02 S2000. I drove around it was fine than the next day when i started her up for work the CEL came on. After work i went by Autozone to check the code and was told it was Seconday Air Injection? Well i installed it correct and all hoses are routed the right way. Kinda confused why it came on most likely i will take it off just cause i dont like seeing it on. LMK if you have guys have an idea on the reason it came up on maybe ? thanx peace
Old Jan 25, 2007 | 03:35 PM
infinity_racer's Avatar
check the hoses right under the TB...theres two small vac hoses that you might've switched.
Old Jan 25, 2007 | 03:37 PM
s2kBryan916's Avatar
Check those and check the little white check valve for correct direction. (second pic in this forum : https://www.s2ki.com/forums/index.php?showtopic=105368)
Old Jan 25, 2007 | 09:01 PM
negcamber's Avatar
hoses reversed
Old Jan 26, 2007 | 02:32 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Old Jan 26, 2007 | 01:47 PM
Mister Jew's Avatar
i didnt touch any of the hoees i only pulled the breather an put it back in the intake and i put the thick rubber hose thats connected to the oem intake into the 2nd hole on the intake. I didnt unplug or reverse anything? i also though our cars had IAT sensors in the intake like obd-2 civics an integras?
Old Jan 26, 2007 | 02:19 PM
negcamber's Avatar
Maybe you could post some detailed pics of the intake and the hoses that do attach to it.
an_orange_s2k
21
Mar 11, 2007 01:47 AM
dnme.s2k
Jan 27, 2007 03:41 AM
jdmfntc
Sep 28, 2006 07:38 AM
mugenrsx
Aug 28, 2006 03:06 PM
shiaochiu
Jan 18, 2004 01:33 AM
